Polyboard .cnc and . tcn export problems|Forum|WOOD DESIGNER
Forum Posts: 918
March 6, 2018 - 11:31 am
Update: this error was resolved some time ago in version 6 of Polyboard. Thanks
January 27, 2016 - 6:47 am
Hi Carol,
We have looked into the tcn error an it seems that there is a bug that inverts the part and so causes the drillings to show on opposite edges.
The development team has closed development on v5 but will be correcting this in v6.
V6 is actually available as a beta version if you are interested in updating.
For the time being I suggest you just use DXF as this works very well with TPA.
You can set up the DXF layer names to import directly into TPA and automatically add tooling.
January 22, 2016 - 7:25 am
Hi Carol,
Sorry to get back so late, but we have been very busy these last weeks and I thought your questions needed some time to answer.
You output tcn code with the ” OPTI{:: OPT2=%;0 OPTKIND=%;1 POSTFLAT=%;1}OPTI ” because you have chosen the Vitap option in the TCN version. This option should be set to “Standard” like this:
tcn-std-vitap.pngImage Enlarger
For the drilling inversions I have tested with DXf and TPA Cad  and there seems to be a problem with the TPA output. I’ll see with the development team today.
For the time being, as DXF works fine, I suggest that you use DXF output for these parts :
top-drilling-dxf.pngImage Enlarger
For your server question, you cannot run Polyboard on your server it needs to be installed on the local machine. You can install the free version on as many machines as needed and transfer projects to the activated version for manufacturing output.
However, you can put the libraries on the server and point several Polyboards to them. Like this all the Polyboard will share and update the same libraries.
You can even put libraries on a web server like DropBox, in this way you even have access to your libraries when not connected to the office server.
This is true for Materials libraries as well as all the others.
For commercials you might find that using Quick Design  materials set to include manufacturing costs is a better way to manage Polyboard projects than using the same materials as manufacturing.
Did you know also that commercials can get the price of a project directly from the free version using a catalog?
Unfortunately, there is actually no way to include directly your logo in the Polyboard documents.
You can however, you can add you logo afterwards by printing to a PDF file and using a PDF editor.
Here is an example of a Polyboard document with your logo added using Foxit Reader a free pdf editor:
catalogue.pngImage Enlarger
workshop-doc.pngImage Enlarger
Hope this is all helpful.
I’ll see with the developers and get back when I have an answer to the tcn error.
Forum Posts: 918
January 18, 2016 - 3:31 pm
Hi Carol, there are so many post processor files types we don’t have all of them allowed for upload. I’ve added .tcn and .cnc to our list so should work fine now. I’ve uploaded your specific files here.
All the best, Stefan
January 18, 2016 - 3:21 pm
Hello Mr. Tillson,
We have a set of questions for you regarding polyboard.
Problems :
Currently our workflow with the CNC files goes like this – we export the files to .tcn , we rename them in .cnc , we erase this code line :
” OPTI{:: OPT2=%;0 OPTKIND=%;1 POSTFLAT=%;1}OPTI ” because our software gives an error and doesn’t open them.
When we have 10 panels is simple, but if we have an entire project its close to impossible.
We need the post processor correct settings. The cnc files you sent us the second time worked just fine .
When we finally open the .cnc files some of them have the wrong holes ( if we have a rectangular board with mini-fix holes on all 4 edges  the holes from the bottom and top switch places )
Questions :
We will have a server ( windows ), that we will access, one person at a time with different accounts ? Can we move the software on this server ? If yes how do we do that ?
Can we have on this server the material and fittings library , so they can be read and refreshed by the users of multiple accounts  ?
Can we load the material library the same as the fittings library ? (for the  demo versions – marketing department)
Can we add the ATIPIC LOGO to drawings and offer ?
Thank you !Capture-our-CNC-Software.JPGImage Enlarger
code-problem.JPGImage Enlarger
corner-cabinet.JPGImage Enlarger
export-settings.JPGImage Enlarger
I can’t upload .cnc and . tcn files – I will send you a email.
Thank you !
Guest(s) 28
Duayne Naugle: 129
Patrick Maylor: 60
dziekan
AKM
Topics: 2095
Members: 258
