Flared / Hours glass Stairs... HELP !!|Forum|WOOD DESIGNER
52
May 12, 2015 - 6:56 am
Hi ness
I have not heard from you and please contact me 07768 456989 ASAP
kevin
51
May 8, 2015 - 7:55 pm
Email me your number please
setterhouse@icloud.com
many thanks
kevin
May 8, 2015 - 9:11 am
Hi Kevin,
I need to talk to you about your project to continue.
Can you phone me ?
Cheers,
49
May 7, 2015 - 8:06 am
Hi ness
any update ?
kevin
48
May 2, 2015 - 11:15 am
Thank you Ness Could you please continue with the Detailed Drawings
Kevin
April 28, 2015 - 8:50 am
Hello Kevin,
Here is a general plan of a curved stair that should work within your constraints.
project02v01.pngImage Enlarger
The objectives of the design are:
– Get the stair close to the design of the photo you posted
– Try to  keeping the start as open as possible to the front door, that is not turning it’s back on the entrance
– Keep the stair within the 3mx3m open stair well.
The first step  is closer than 1m80 to the outer wall but the stair will not be facing away from the front door.
I can turn the stair faster and move the first step away from the front door, like your architects drawing but this will put the stair more or less back to the front door and the living room.
With the design you have chosen, in my opinion, the whole stair should be curved. Adding newels will break the movement and flow of the stair. Of course this means that the stair will be more expensive, so it might depend on your budget.
As with everything it’s always a question of compromise.
If this plan is OK with you we can move forwards and draw the details.
Have a look at the project and I’ll call you so that we can discuss how we move forwards.
46
April 23, 2015 - 11:55 am
Kevin Law said
curved-stairs-april-2015.jpgImage Enlarger
Dear ness
can you please update me ASAP 07768 456989
regards Kevin
45
April 11, 2015 - 1:14 pm
44
April 11, 2015 - 12:33 pm
Thank you
This seems to work
I would like the stairs to start 600m in from the right hand side of the gallery
and would like the stairs as much like the picture I attached last as possible with the “Grand Piano” bottom shaped step and with the newel post being set behind (as per the picture)
and with the right hand side of the 2nd to bottom step kicking out (like the picture)
basically I would like my stairs to as much like the picture as possible
how quickly can this be done ?
Best Regards
stairs-1-1.jpgImage Enlarger
Kevin
April 9, 2015 - 5:35 pm
Hi Kevin,
It’s possible to make the stair curve up like this:
project01v04.pngImage Enlarger
Advantage being a simpler design and more elegant curve , disadvantage is that the stair back is seen from the living room.
all the best
Currently Online: Ray
Guest(s) 19
Patrick Maylor: 60
Topics: 2099
Members: 260
