How to create a Chamfered Finger pull|Forum|WOOD DESIGNER
November 5, 2016 - 6:03 pm
Hi Michel,
Thanks for this trick, I think that Alex did the same.
We are waiting for the developers to have the time to add a moulded edge function.
Unfortunately they already have a long list of newbies to add and I doubt that we’ll get this quickly.
Forum Posts: 984
November 5, 2016 - 5:20 am
i did find a way to make it via a project but when the door opens in 3d the added panel does not stay in sync with the actual door.
October 28, 2016 - 5:39 am
Hi alex,
Can you post the Polyboard model that you made?
regards,
October 27, 2016 - 11:57 pm
What I did to give me the desired effect is to reduce the door thickness be 5mm and then apply a 5mm panel to the front of the door.
It now looks like what I want.
Ness if there is a better method please share for both presentation and machine files.
October 27, 2016 - 11:45 pm
It’s mainly for presentation.
October 27, 2016 - 5:29 pm
Hi Alex,
Polyboard can’t create a chamfer as you want it.
You can do it but the method you use depends on why you want it.
Are you looking to create a detailed presentation or do you need machine files?
October 27, 2016 - 10:32 am
Hi Ness/Stafan,
I want to create a 45 degree chamfered finger pull along the inside top edge of my doors.
Polyboard does have a chamfer setting that creates the finger pull I want (sort off). The only problem is the finger pull is created with a sharp edge, where I want the chamfer to start 5mm from the top front edge.
Can this be done?
Currently Online: Alex
Guest(s) 31
Duayne Naugle: 129
Ray: 59
Patrick Maylor: 57
dziekan
AKM
Garyh
niharbu
Daniel Jones
Topics: 2075
Members: 254
