My first stair|Forum|WOOD DESIGNER
My first stair
September 15, 2016 - 8:20 am
Hi Stig,
Yes, I’m sure that the back of the pockets are extended 28mm, I’m not sure why this came about.
If the stairs are painted filling in the pockets is certainly easier to do.
You’ll have to see directly with Stefan for compensation.
40
September 13, 2016 - 9:36 am
Ness said
Hi Sig,
Sorry to get back so late but I have been away this last week.
It seems that the step housings in the dxf parts are extended 28mm on the back edge.
This has only appeared in the sting dxf files and could be a configuration error in the dxf set up.
The only explanation I can see is that I’ve forgot to re-set the dxf config after using StairDesigner for another client, so I do apologize for this.
As the housing are already routed out, to fill the extra hole, I would suggest gluing  to the back edge of the steps, either a continuous batten:
step-modif-010.pngImage Enlarger
or 2 gussets :
step-modif-020.pngImage Enlarger
Both solutions should work and give an elegant finish.
Sorry again about my mistake,
Well, the stringboards are gonna be painted, so i guess it will be less work to fill 28mm of the back of the step-pocket.
Are you sure it is the back of the pocket that is extended ?
And…dont you think this is a money-back issue for the stair-file?
thx
Stig
September 13, 2016 - 9:16 am
Hi Sig,
or 2 gussets :
38
September 13, 2016 - 8:49 am
*BUMP*
37
September 11, 2016 - 10:31 am
Ness said
Hi Sig,
Here are your files.
Hope the build goes OK for you.
Keep us updated.
I cut out all of the parts a while ago, and today i was about to fit them all together.
But…. All pockets in the stringboards ( for steps) is approx 28mm too wide !! And when i now check the drawings, i see the steps will not fit… How could this happen ?
June 27, 2016 - 4:42 am
Hi Stig,
Thanks for posting your photo, it looks great!
35
June 21, 2016 - 6:24 pm
Thanks !!
Installation of my first stair right now…2016-06-21-20.22.16.jpgImage Enlarger
June 21, 2016 - 5:07 pm
Hi Sig,
Keep us updated.
33
June 21, 2016 - 4:56 pm
thanks, it looks good to me 🙂
June 21, 2016 - 4:50 pm
Hi again,
I’ve deleted the last post and set the second flight to 3410 leaving 5mm clearance at each wall.
Can you check to see If this is OK for you and I’ll process your files.
Guest(s) 23
Duayne Naugle: 129
Ray: 59
Patrick Maylor: 57
dziekan
AKM
Garyh
niharbu
Daniel Jones
Topics: 2075
Members: 254
