problem with adding banister|Forum|WOOD DESIGNER
August 9, 2016 - 8:09 am
Hi Morgens,
You can’t add banisters because they are deactivated in the flight parameters.
To activate these, move the mouse over the flight and click right. In the menu choose “Flight Parameters”flght-para010.jpgImage Enlarger
In the Flight Parameters dialogue box tick “Right Banisters”.
activate-spindles.jpgImage Enlarger
You have to do the same for both flights.
The circular option in handrails is a function that has never been developed, so just ignore it.
The “Height beyond steps” parameter displays a warning  message when the step housings get too near the lower string edge.
The message is only shown when you go to  Display> String boards.
dist-behind-steps.jpgImage Enlarger
Your stair has very narrow steps which make it dangerous to descend.
In this case I would consider using alternate steps.
Hope this is helpful,
August 8, 2016 - 11:32 am
hi
why can´t i add bannister in the attached stair. i now that the stair isn´t the best designed, but there is not space enough to get a better staircase.
and why is there a circulair area in handrail parameters but you can´t use it (not possible to mark up)?
in stringboard parameters i can add a “control of minimum height beyond steps”. I can´t see that it make a different.
the 2 last question have no reference to first question, but is at general speaking.
Guest(s) 24
Patrick Maylor: 62
Topics: 2102
Members: 260
