We’ve had a lot of requests to add more Camar fittings to PolyBoard, our cabinet software solution. In particular, our customers were keen to include Camar’s range of cabinet feet, plus 3D visuals, and also a selection of cabinet hangers.
Here’s a quick summary of the configurations we’ve included. As usual, PolyBoard provides the machining details for the fittings on the plans of each part, and embedded in the CNC files, instantly available for manufacturing.
Cabinet feet
Camar is based in Italy and has a global reach in a particular market niche, cabinet feet (or legs) as well as hanging brackets.
To take cabinet feet first, we’ve included the following ranges:
- Classic: in plastic (ABS), 80 – 150 mm
- Classic: in steel, 100 mm
- Ercolino (next generation): 60 – 100 mm
- Leveller: fixed to side panel
Here’s an example of the Classic 80 mm feet in ABS applied to a PolyBoard kitchen model. The plinth is set to semi-transparent so the feet are visible in the 3D render.
Hanging brackets
We’ve configured a range of Camar’s brackets to work with PolyBoard designs, both for wall units and base cabinets, with visible, concealed and inset options.
Models include:
- Visible hanging brackets: 704, 801, 802 and 806
- Mounted on the side panel: 807
- Concealed: 816 and 817
Download your Camar fittings
The full collection of Camar fittings is available as a hardware pack, downloadable from your account page and exclusively available to Premium Support subscribers.
We’re adding to our hardware range all the time, keep an eye on our newsletter and the forum for details. If there are any additional fittings you’re interested in, just let us know and we’ll do our best to add them.
