Continuous curved central cut strings give a very elegant design for modern stairs, but the curved stringer and handrails can be long and expensive to manufacture.
A compromise is to make the string and rail in straight sections bolted together.
The handrail is assembled around newel posts and there’s no need for wreathed sections.
Using horizontal laminates, this sort of stair can be made by an amateur woodworker although I strongly suggest that the plans be drawn up by someone with experience in this type of construction.
Here’s the plan of a stair that I have just completed for an amateur stair builder:
clip_image002
StairDesigner can’t construct the straight strings so it’s DXF files have to edited in CAD to get the straight extensions.
Here’s the original Stair Designer project :
cut stringer stairs
Note how I use an outer boxed string to simulate the lower railing of the left hand balustrade.
To see how to do this have a look how the parameters are set in the StairDesigner file you can download below.
You can also have a look at this article:
How to Design a Wooden Handrail for an Existing Stair with StairDesigner
The stringer and the handrail are modified using ProgeCad.
Here is a rough out of how the string will be set on site with the straight sections :
clip_image004
And this is a rough rendered view of the stair :
central stringer staircase
3d02
3d03
The strings will be built using horizontal laminates.
As usual if you have any questions or remarks don’t hesitate to leave a comment.
2 Comments
  1. admin on October 13, 2013 at 6:30 pm
    Hi Brad,
    I’m using StairDesigner 6.51 , don’t have any problem opening the file my end.
    I’m sending you a link to update you version via email.
  2. Brad on October 13, 2013 at 11:38 am
    Hi Ness
    Which version of Stair Designer did you use to create this design? The .sds file in the zip will not open in either v5 or 6.
    Many thanks for your help.
    Brad
