A huge range of emuca fittings and hardware is now available for fast and accurate application in our PolyBoard cabinet software.
Here’s a selection of what’s included. If you don’t see the hardware you use in your workshop, just let us know. We’re very happy to add more!
Drawer systems
Durable, mutil-functionable drawers in a range of modern finishes.
  • ULTRABOX drawers: quick to assemble and durable, great for kitchens and bathrooms
  • VERTEX: versatile, soft close, highly adjustable, aluminum/white/anthracite
  • CONVEX: push to open and soft close, minimalist design
  • CONCEPT: modern finishes in anthracite gray/white
Lift systems
H piston lift systems
Smooth vertical opening and closing of cabinet and cupboard doors. Both lift-up and fold-down options.
H piston lift system from emuca
We have set up multiple products in the range including the thin diameter 12 and the folding piston options.
Note that emuca provides a range of data tables and advice to help you choose the right piston system for the door dimensions and weight.
Slimwinch lift system
This folding door system incorporates a steel cable and can hold up to 9kg. The mechanism can be surface mounted as shown below, or fitted into a recess in the cabinet side.
Slimwinch emuca lift system available for use with PolyBoard
Cable length and spring force is adjustable. Opening and closing is damped and assisted.
Hinges
Steel and highly durable alloy hinges, complete with soft close mechanism.
Full and half overlays, insets, range of opening angles and configurations including the X12, X50, X91, X92, X95 and the C91.
Also available are the reduced size Ankor GT-B hinge for delicate furniture (see image above), and the concealed flap hinge.
CAMs
A range of high precision CAM assembly systems including the Rostro shown below.
Rostro cam system from emuca
Miscellaneous
Finally, we’ve included a range of emuca door accessories to complete your cabinet design.
These include:
  • Push Lite door closers, recessed and simple screw on
  • Push Latch door closers, supports and covers
  • Concealed support for Wooden Shelf Simply system
  • Luna shelf support
  • Cabinet feet
Get started with emuca and PolyBoard
Add your favourite emuca hardware into a style sheet of construction preferences. Then apply with the click of a button to all your designs. Flexible hardware rules automatically adjust positioning dependent on your cabinet dimensions.
The emuca Hardware pack is available as usual from your account page.
All hardware packs are exclusive to Premium Support subscribers, we’ve also provided a selection for testing as part of the free Quick Design libraries download.
Please also note, a complementary Premium Support offer is available with your first PolyBoard order.
