Cnc-cutting depth and number of passes|Forum|WOOD DESIGNER
michael hibbins
Forum Posts: 16
November 8, 2022 - 1:07 pm
thank you michel
November 8, 2022 - 10:09 am
Hi Michael,
In the pp setup under profiling, you can find the parameter “tool vertical overlap”. There you can mention the 0.2 value through the panel
for the 2mm second pass I have no idea if and how this is done in Biessenest, but in Polyboard you can use the residual thickness parameter that should leave that value for a second pass. This will be for all parts, but it is always better to cut through a part with less material resistance even if it is a bigger part
biesse.pngImage Enlarger
michael hibbins
Forum Posts: 16
November 7, 2022 - 8:38 pm
hello there!
fairly new to polyboard and just learning, been playing with exporting to Cnc (biessenest cid) and when I optimise it flags that the profiling is to deep.
1. where can I set this parameter up to be 0.2mm past the piece?
2. on some smaller pieces i like to do 2 passes with final pass 2mm holding its position better, is this done within polyboard first or biesseworks after ?
thank you
Currently Online: Aurelian Draghici
Guest(s) 126
brendan kavanagh: 212
Zaheer Abbas: 158
Tom Jackson: 113
Aurelian Draghici
Rory Parker
Harish Kiran Jetti
Gerard McDonagh
Livvy Kendrick
Esteban Raisiere
Monica macias garcia
arno.s
JP123
Topics: 2777
Members: 486
