Im new to all this and im trying to set up the post processor to output dxf files to maestro. I have set the overall base panel layer to XYLP1H18.5 and the outline layer to XLYP1T$OUTLINE$ however when i import the files into maestro the following error appears “The textstyle width factor valid values range from 0.01 to 100. Parameter name value: value. Actual value was 0.” When I click ok th import dxf imformation box comes up but there is no layers in it to import. Any ideas?
