set up libraries|Forum|WOOD DESIGNER
set up libraries
Forum Posts: 1040
August 22, 2022 - 9:13 am
Hi Sean,
I am currently on holiday and will be back next week. what are your availabilities to have a short session about this?
Also, try to prepare some visuals from your Biesse software in order to evaluate.
sean kennedy
Forum Posts: 12
September 20, 2016
August 4, 2022 - 5:28 pm
Hi Michel
I had a go at that today but no luck .The tenon at the bottom of the stringer is being made two short the thickness is ok . And the one at the top also seems to be short but i didnt let it finish that one. Could you have a look on team viewer at some stage .
Forum Posts: 1040
August 4, 2022 - 10:08 am
Hi Sean,
As discussed on the phone please test the clockwise direction on the inner toolings orientation parameter and revert with the results.
sean kennedy
Forum Posts: 12
September 20, 2016
July 28, 2022 - 4:10 pm
Hi michel
I had to change some of the names on the tools to get it to work but it is doing it now. I have also set up the aggragate on it but am still having some issues on the drawing the tenon out line is there but when it goes to biesse works its not and the aggragate cuts the wrong place.
Forum Posts: 1040
July 25, 2022 - 7:32 pm
Hi Sean
We did not add any tool on the  (inner) for the step risers and notches. Add the same tool there as on the (outline) and try again
If you still have a problem then try again with  the parameter  “group Step and Riser notches set to NO
biesse-cix.pngImage Enlarger
sean kennedy
Forum Posts: 12
September 20, 2016
July 25, 2022 - 4:04 pm
Hi Michel
I tried to run a short stringer on the cnc this after noon but no luck the outside cut out seems ok but the pocket for the steps and risers is not happy it gives a warning that the tool size is wrong but i have checked the machine and the name and the sizes seems ok .
sean kennedy
Forum Posts: 12
September 20, 2016
July 22, 2022 - 1:56 pm
Hi Michel
That will be perfect thanks.
Sean
Forum Posts: 1040
July 22, 2022 - 1:41 pm
Hi Sean,
Can we have a zoom session Monday at 9 AM your time to try to sort this out for you? If you confirm I will send you an invitation via email. Please gather all needed information from your tools and machine that we will need during the setup.
sean kennedy
Forum Posts: 12
September 20, 2016
July 22, 2022 - 11:34 am
Hi Michel
Thank for getting back to me and so for the late reply i was out for a few days.
We got the libraries to work it was the fire wall was stopping it .
As regards the post issue we changed the computer a while back and lost all of the set up so i have just been using dxf for the last few stairs we have built .
So it would be great if you could help use to sort the post out .
thanks again
Sean
Forum Posts: 1040
July 19, 2022 - 12:36 am
Hi Sean,
You probably used older libraries and the new ones only work with the latest version of polyboard so please update your software.
About your CNC output, you had the needed session with our technician to get it aligned properly with your machine. We could have a short zoom session on Tuesday 19. Let me know what time suits you the best to send you an invitation.
Most Users Ever Online: 365
Guest(s) 44
brendan kavanagh: 179
Tom Cleaver: 164
mark nichols: 162
Conor Devoy: 158
Zaheer Abbas: 132
Blake Simpson: 104
Patrick Maylor: 84
Tom Jackson: 83
Rick48
Hassan Sultan
Carmela Di Sorbo
Telmo Oliveira
Jesus Vergel
eduardo beiza
lucas Lucas Moreno
Efthimis Stathas
Rayallie
Topics: 2512
Members: 393
