toolpath cutting |Forum|WOOD DESIGNER
brendan kavanagh
Forum Posts: 209
May 12, 2020
OfflineHi
Can you take a look at the file attached, we have a 60mm style on this door and we need this to be 60mm when cut out.
I don’t do this too often so can you look at the toolpath specifically the machine vectors i have set it to outside/ right on the first cut 1- 9mm and cut 2 -15mm (only going down 15mm not all the way) will this leave the 60mm??
Hope this makes sense
Thanks Caroline
Guest(s) 76
brendan kavanagh: 209
Zaheer Abbas: 156
Patrick Maylor: 114
Tom Jackson: 113
Monica macias garcia
arno.s
JP123
Cristian mihoreanu
Jurij Avizen
H
magnus rehn
Stephanie Olaverry
Gustavo Muñoz
Topics: 2758
Members: 480
© Simple:Press —
