Forum Posts: 885
brendan kavanagh
Forum Posts: 107
May 12, 2020
May 12, 2020
Forum Posts: 885
Hi Caroline,
It is possible to handle it in 2 different ways.
1 Manually in v-carve by selecting the parts you consider as small.
2 If you are using the toolpath template in v-carve then there is also a possible automated process using the multiple postprocessor output of polyboard. there we can select parts on max height and width and process them. This will result in a layer name that is different for small parts and the bigger parts. This will allow you to handle the machining order via the toolpath template and make sure small parts get a finish cut first.
Currently Online: Ramon Hagenthurn, sukkoo Kavirawsing
Guest(s) 1
terry: 253
mark nichols: 157
Kerf Works: 143
Tom Cleaver: 143
Conor Devoy: 131
Duayne Naugle: 122
brendan kavanagh: 107
jimbouk: 105
Syslab Corp: 103
Stu Robertson: 102
hawk gripen
david s
Dávid G
Emil Bergström
Jose Antonio Lope
isaac kim
Rodrigo Alvarez
poes Kat
Plakkie Kat
john tikis
Topics: 1780
Members: 148837
Administrators: Ness, Stefan, Michel, Carole, Alex, admin, Laly, ipatrick, Fatima, Crystal, Jem Turner, Darren
