vcarve pro|Forum|WOOD DESIGNER
vcarve pro
December 29, 2021 - 12:23 pm
Hi Mohamed
Our software should work with your machine, however, I would strongly recommend that you download the trial version of VCarve Pro and machine at least one of the “Evaluation Files to Machine” that are included with the trial edition of the software, to test the output from the post-processor with your particular machine.
Trial Download: https://wooddesigner.org/vcarv…..-software/
Once installed, on the start screen select “View Sample Files”.
This will open your Web browser (such as MS Edge or Chrome) on the Machinable Tutorials Page.
Here are a number of tutorials you can output the toolpath for.
The “Bulls Head” evaluation file, is usually a good test of a machines 3D capability.
The “Avalon Sign” contains some arc moves in the profile toolpath and would ensure that the arc configuration of the post-processor matches that required by your machine.
The trial edition includes a Rich Auto A11 Post Processor that should work with your machine, so you can test its compatibility.
You can see the Machine Configuration Guide tutorial video here: https://www.vectric.com/suppor…..tion-guide
December 28, 2021 - 8:19 pm
hi
thanks alot anyway , i have contact the supplier and they   advise me to use G code mm .Tab  post processor and it works fine  , i just need full toolpath  tool datebase list in metric
  thanks
December 27, 2021 - 10:39 am
Hi Mohamed
this is a holding message to inform you that we are investigating.
We will revert asap. It could be of help to send us your current gcode for a simple part.
Provide us with the part information and the Gcode. Please use a simple rectangular geometry with a few drillings and profiling.
December 25, 2021 - 8:34 pm
FULING INVERTOR AND stepper motor and cuting moter HQD 6hp20211225_150308.jpgImage Enlarger
20211225_150542.jpgImage Enlarger
20211225_150549.jpgImage Enlarger
December 25, 2021 - 1:31 pm
hi
my controller is FULLING and i am using hand controller richauto A11
December 25, 2021 - 11:13 am
Hi Mohamed
what is the type of controller on your machine and the full brand and type of your machine ?
December 24, 2021 - 9:27 pm
Hi ,
i am using output file as g code  for my cnc machine Lang (mm) .cnc   in artcam 2018 which post processor  output can use in v carve pro for my machine
  thanks
Guest(s) 50
brendan kavanagh: 209
Zaheer Abbas: 156
Patrick Maylor: 114
Tom Jackson: 113
Cristian mihoreanu
Jurij Avizen
H
magnus rehn
Stephanie Olaverry
Gustavo Muñoz
Maciej Jaworski
Eleanor Maple
Topics: 2755
Members: 477
