Bottom in drawer|Forum|WOOD DESIGNER
Bottom in drawer
April 10, 2025 - 1:30 pm
Ho sorry I got it!
The actual groove length in this fitting only made 550mm,  and can be up to 650mm
From menu Libraries > Fittings > Fittings
legr-bot.pngImage Enlarger
But caution in cabinet you send,  the drawer sub-methods used is BLUM/Movento, so the parts of drawers is not good
drw-sub.pngImage Enlarger
Ola svensson
Forum Posts: 100
April 10, 2025 - 12:36 pm
Thanks for your reply.
think we are talking about different things, maybe I didnt explain it all that good 😉
 on the drawer bottoms we need the grooving to go all the way back underneath the whole drawer bottom along both sides to fit the Legrabox drawer sides.
I have changed the boxful but the grove are still not along the whole length of the bottom. Any ideas?
Kind regards, ola
April 10, 2025 - 11:50 am
If I well understand you talk about recess create per your Nil back ,
nil-back.pngImage Enlarger
In fact, a panel defined as Nill is not actually suppressed, so it should be considered as glass without thickness,
You can’t go through it, you don’t see it but all the parameters remain active, like a groove, or here the Top, the bottom and the sides that go beyond it.
nil-back-2.pngImage Enlarger
And so what reduces the drawer zone here
Hope that’s helpful,
Ola svensson
Forum Posts: 100
April 10, 2025 - 11:10 am
Can you please advise on why the cut is not going all the way for the grooving in the bottom of the drawer in this PB file?
Thanks!
Kind regards, Ola
Currently Online: Christian GLENET
Guest(s) 35
Christian GLENET
mohammadmaghari
Petru
Trojan Construction
Islam Boukouiren
Topics: 2970
Members: 566
