Change the tooling for a cabineo?|Forum|WOOD DESIGNER
Forum Posts: 2128
Please find hardware attached as compresser zip file,
Please uncompressed it then importe them into fittings,
Ola svensson
Forum Posts: 100
January 20, 2022
Can you please advise on how to change the tooling in fittings for the cabineo to a groove so that I can use a milling tool instead of a drill? So that I afterwards can export it to the cnc?
I changed the setting to groove and put in the right measurement, but of course then the circle disappeared… What is the work around to get this right, and why cant you just change if you want to groove or drill in the settings?
And another question, how come not all of the Lamello fittings is in the overview of fittings? I can’t see the ClamexP10 and Tenso fittings.
Kind regards,
Caroline
Currently Online: irmantas Dargevicius
Guest(s) 55
Javier Velázquez
sjust
Topics: 2932
Members: 553
© Simple:Press —
