circle cut on vcarve |Forum|WOOD DESIGNER
Video below
or DXF attached, you can import into Vcarve
panel origin from bottom Left
OfflineHi Alex
sorry im really not following that video, I can you give you the sizes of the one im trying to do
board is height 1920 x width 1020 with a rectangle inside size of h= 1880 x w=980 then 1 x circle is 860 cut out , then a second circle cutout in that is 720
the centre of the circles has to be 645 from top of board i have attached screenshot of file could not upload for you ![]()
hope this all makes sense
Thanks again Caroline
OfflineHi Caroline,
please find the video on how to do it
OfflineHi
Following on from last post re cutting out circles on board, i now have to move the circle a certain distance on the board
The center of the circle is now going to be 645mm from edge of the board (previously it was set in the middle)
Can you send me a video on how to do this?
Thanks very much
Caroline
