Grain direction in Vcarve|Forum|WOOD DESIGNER
I did DXF export in Polyboard. Then i did batch dxf import to Vcarve.
If i set material X1220, Y2440 in Vcarve, the grain direction of wood is not correct.
If i set material X2440, Y1220 in Vcarve, the grain direction of wood is correct (see attached file).
But, in the CNC nesting machine, X axis is 1220, Y axis is 2440.
How to make the cnc understand the correct direction?
Thank you.
Currently Online: Christian GLENET
Guest(s) 34
Christian GLENET
mohammadmaghari
Petru
Trojan Construction
Islam Boukouiren
Topics: 2970
Members: 566
© Simple:Press —
Offline
