KDT 2309D|Forum|WOOD DESIGNER
KDT 2309D
August 9, 2018 - 1:07 pm
Hi Shefeek,
Polyboard can export MPR and DXF so this should be OK for running the machine.
You will have to set up the Polyboard export to suit the machine tool setup but that should be no problem.
You can download some example files from here:
August 9, 2018 - 11:37 am
They confirmed the Machine can take files with the following extensions .xml , .pdx , .mpr , .dxf and .bpp file.
The CAM software they say is TREPAN.
Shafeek
August 8, 2018 - 1:30 pm
Hi Shafeek,
Polyboard can’t output HMPL or MPL format, but can export DXF.
Polyboard can out put for standard machines like Biesse, Homag, HolzHer, Felder, Vitap and generic DXF. See here for more details:
In general most machines can import DXF, what CAM program is delivered with the machine?
August 3, 2018 - 11:55 pm
Hi Ness…Not a problem…enjoy your vacation
The company told they use HMPL or MPL format…Does Polyboard use this format ?
What output can Polyboard produce ?
Shafeek
July 31, 2018 - 6:51 am
Hi Shafeek,
Sorry to get back to you so late, but some of our team is actually on holiday so we are running behind.
I don’t know the KDT machines.
Can you tell us what CAM software is running the machine and what file types it can read to produce the tool paths?
PS: I’m also actually on holiday so please excuse me if I don’t get back very quickly.
July 27, 2018 - 2:17 am
Can Polyboard output work with KDT 2309D Drilling Machine ?
Shafeek
Guest(s) 39
