mpr number in cutting list|Forum|WOOD DESIGNER
Just to informat issue hasbeen identified and update coming soon,
I can’t download from your link,
I have send mail can you send it from this mail,
But looking at your cabinet and chamfer, IF your booth does not have an angled hole, these will not be handled properly.
(Tools menu > Preferences)
3 Axis cnc can only drilling at 90° or 0° angle,
The second constraint is in the PP options, here you have a panel with a lower and upper angle on the top,
as far as possible, the pieces will also follow this constraint
OfflineCan you send me your PolyBoard PP, or more easy a backup from menu Tools, Save paramètres ( without textures)
I’m not sure I understand,
can you join the cabinet and your PP?
Export the original file and edit it if you are able to do so
and what do you want to achieve?
