nesting and side doweling on maestro|Forum|WOOD DESIGNER
OfflineEmanuel,
Perfect, have a look in Maestro at your 8mm tool set-up and parameters. It seems to be ok from PolyBoard.
OfflineEmanuel,
Thanks, that is the file.
Do you have the following drill bits on your CNC machine:
– 3mm drill
– 5mm drill
– 8mm drill
– 20mm drill
If you would prefer, you can send me a photo of your drill bits in the Maestro Tool Manager.
OfflineHello Emanuel,
Yes, you sent me the Maestro files. I need the PolyBoard project please, so I can open it on PolyBoard.
OfflineEmanuel,
I need the PolyBoard file please, of the cabinets.
Thank you, Isaac
OfflineDear Isacc
I AM USING THE DOWEL RANGE PROCECER,AND ONE UNIT CAME GOOD .oNLY THE SIDES OF THE OTHER UNIT ARE GIVING ME PROBLEMS THAT IS STRANGE BECAUSE THE HOLES ON THE SIDES MUST BE SOMETHING EASY TO DO AND THERE IS A LOT OF OTHER HOLES THAT ARE DONE .THE DOWEL HOLES ARE GIVING ME PROBLEMS.
THANK YOU
E SACCO
