Outcoming files for CNC|Forum|WOOD DESIGNER
OfflineHello,
The first ones I sent you are directly from the Hafele page.
The others are made in PolyBoard. These cannot be lighter in size.
See more information for making 3D elements:
See the others attached.
OfflineHello,
No worries, here is a reduced version.
Note, this is not as detailed, although dimensions should be correct.
OfflineHello,
See the attached dxf files. These are ready to import into PolyBoard.
According to Hafele, these are for Axilo H120-H150.
OfflineHello Girts,
Can you please send me the technical sheets for the two Axilio’s that you are referring to.
Then, I can prepare some models for you.
OfflineHello Girts,
Can you also send me your latest parameter file please?
OfflineHUSTON WE HAVE A PROBLEM.
There is problem with outcoming excel file – when I am in model and I`m making Post Processor export – edgebands are exporting correclty, but when i`m making export for project – the colums in excel are switched – edgeband width is mentioned as height and otherwise.
Please see the plyboard file.
