oversizing panels|Forum|WOOD DESIGNER
Forum Posts: 2128
When you oversizing par like this that just said how much you want add on parts for pre-cut to calibrate on CN (height / width /2 per edge),
In other words, it does not oversize parts to fit them when they are installed on your customers’ premises, for example.
To oversizing panel you can edit shape manually, or add negative recess value
Forum Posts: 2128
Can you upload your project and tell me which version you’re using?
The tests carried out with the latest version did not show any anomalies.
Currently Online: Fatima
Guest(s) 53
Pavel Kudrjavtsev
Javier Velázquez
Topics: 2933
Members: 555
© Simple:Press —
