PolyBoard and Holzher's BetterNest|Forum|WOOD DESIGNER
January 3, 2018 - 9:43 am
Hi Rafal,
I’m not an expert in BetterNest but you are right in assuming that if BetterNest will read .hop files then you will be able to use them directly in BetterNest. You might need to tweak the Polyboard PP setting but it should work OK.
The best would be to try  and eventually ask Holzher.
Wishing you a happy and prosperous 2018
January 3, 2018 - 8:58 am
Hi all,
I want to ask if anybody knows if PolyBoard will work with BetterNest (from Holzher). We bought nesting CNC from Holzher and will get BetterNest together with it. This will be the first time for our company to use nesting CNC so before it will be delivered we want to prepair ourselves to start utilizing it asap.
We already have 5 axis and 3 axis CNC from Holzher which work with Campus software that reads .hop files that we export from Polyboard. Since Polyboard can export .hop files and obviously does it one file per part, is it safe to assume that that BetterNest will be able to take those files directly from Polyboard and nest them? Or are there additional steps that need to be taken?
Thanks in advance!
Guest(s) 44
