Polyboard to VCarve dxf problem|Forum|WOOD DESIGNER
January 16, 2020 - 7:55 am
hi Eoin Bracken !
You don't need to do that. Go to the cutting lists and the table of your choice will look like the one I sentaaab-compressed1.jpgImage Enlarger
Carole
Forum Posts: 73
June 10, 2019 - 5:46 pm
Hi again Samer,
Thanks for these details and video.
You have very interesting skills.
I send you an email for more information.
Carole
June 10, 2019 - 3:28 pm
June 10, 2019 - 2:59 pm
No worries Mrs. Carole.
By the way, I am a CNC Technician with 10 years of experience specialized in integrating Polyboard with CNCs and Panel saws automatically. I also train factories on polyboard and opticut. My expertise is with SCM, Biesse, Holzher, Weeke and some chinese machines.
Samer Chami
Carole
Forum Posts: 73
June 10, 2019 - 7:10 am
Thank you Samer for helping Eoin.
That’s the whole point of this forum, to create a community of mutual support between users.
Beautiful day for all of us
Carole
June 9, 2019 - 4:48 pm
That is brilliant Samer
Much appreciated
Eoin
June 9, 2019 - 1:45 am
Hi Eoin,
in order to solve this problem, you should go to Cutting Lists in the menu bar then cutting lists options and select “Individual cutting list” instead of “Grouped cutting list”. in that way, each part will be exported as a single file.
Samer
June 8, 2019 - 2:10 pm
Hi Guys
Eoin Bracken here
we have a small problem with exporting dxf files from polyboard to vcarve. if we export a cabinet that has blank end gables or if it has multiple shelves of the same dimensions polyboard only exports one dxf file for the identical parts
ie a cabinet with 6 adjustable shelves, only 1 shelve will show up in vcarve
our quick solution to this was to vary the depths of shelves in increments of 0.5mm but this can lead to errors when designing a cabinet from scratch.
any help would be much appreciated.
Eoin
Guest(s) 18
Topics: 3003
