Post processor setting - machine mode|Forum|WOOD DESIGNER
You need to use standard mode!
The goal when configuring a PostPro by yourself is to go little by little!
For example, make an export with simple drilling, and if that’s OK, do to the next step,
Drilling + Slotting, if OK do to the next step,
Drilling + Slotting + Internal machining ; If ok….
like this you can easily identify an wrong setting
For info “Macros mode PP This was a specific development option for which a charge was made, for a customer who wished to replace all Standard machining with Macros that he had written himself, so this have no effect on a CNC machine that did not have these particular macros installed
Hope this helpful, Alex
Guest(s) 64
Conor Devoy: 173
Jan Peter Oelen
ANDI MÖÖBEL - Tarmo
Topics: 2964
Members: 562
© Simple:Press —
