shaker doors|Forum|WOOD DESIGNER
shaker doors
January 9, 2023 - 8:35 am
Michel tried to call you but there was no answer. Have you been able to clarify this point?
brendan kavanagh
Forum Posts: 236
December 5, 2022 - 3:49 pm
Hi Alex
I have attached back and front of shaker doors i have done in vcarve (disregard the hinges in back of door)
Thanks Caroline
  • sp_PlupMedia back-of-door-shaker.zip(21 KB)
  • sp_PlupMedia Door-1.zip(22 KB)
December 5, 2022 - 2:22 pm
would it be possible to show me an example of your doors, but for me it’s more a question of pass depth than speed,
in general as chip thickness, rotation and feed rate are related, it is preferable to make several passes rather than slowing down the machining or rotation
brendan kavanagh
Forum Posts: 236
December 5, 2022 - 12:40 pm
Hi
Can someone look at my question please would like to run the door again today
Thanks Caroline
brendan kavanagh
Forum Posts: 236
December 2, 2022 - 2:00 pm
Hi
we are starting to do shaker doors on cnc, but one question we are using a end mill 80mm to do the pocket the spindle speed is 24000 which is fine when skimming board but is too fast for these doors what speed do you recommend for doors or is it just we reduce speed and see what works??
Thanks Caroline
Guest(s) 52
brendan kavanagh: 236
Emmanuel Sacco: 210
Zaheer Abbas: 201
Tom Jackson: 142
Rooms Made Simple: 132
MobLux
Valentin Zarzara
Kendal Anderson
Sarah J0hnson
Andreas Nygårds
Nicolas LEBRETON ROOST
Luka Savić
Lee Gent
A S Brighton
Tobias Briander
Topics: 3062
Members: 602
