Solution for XILOG MAESTRO nesting "piece naming"|Forum|WOOD DESIGNER
OfflineHi there,
Can you use our contact form, link below, to introduce yourself to our team.
We can then have a chat about how to work together if you’re interested.
Thank you, premium sounds good 🙂
I wrote opticut postprocessor for new SCM saws that runs new version of “wincut” now called mestro cut. Its very diferent uses kind of xml format, header , folders, label data, LST files are nov XMIX files and 001,002 files are now 001.xprg 002.xprg and so on on but the cutting sequence is simmilar.
here is the tested post developers can implement it in to new verrsion of opticut.
Looks like developers are too bussy 🙂
code is probably not showing right so please download it from attachment
<! Paramčtres d'export !> <file=xPrg\*_???.XPrg|8.3> <varSep=,|subst=\,> <varGrpStrip=1|ctrl|optSpec=7> <! ATTENTION: ŕ placer avant 'ctrlMaxCut' !> <! Contrôles de l'optimisation !> <! ATTENTION: ŕ placer avant 'ctrlMaxCut' !> <ctrlMaxCut=100|l=tcEsrp> <! ATTENTION: ŕ synchroniser avec !> <ctrlMaxCutDepth=4> <ctrlMaxCutMapQty=9999> <! Un fichier par plan de coupe !> <varUnit=md3z> <! millimčtres avec 6 décimales !> <! En-tęte du fichier !> < <<HeaderDescrizione="<mat:ref|fmt=50>"Spessore=""Date="12/01/17"Lunghezza=""Larghezza=""SpessoreLama="4.400"/> <<MaterialTipologia="TYPE"Codice="MAT"/> < <! ATTENTION: ŕ synchroniser avec !> <tab=2><<CutT="P"Dim=""Rip="1"ID="1"EtiID=""/> <enumItem|l=tcEsrp> <! ATTENTION: ŕ synchroniser avec !> <tab=2><<CutT= <! Code de coupe !> " <CutLine=t><<CutT="R <CutLine=tc><code|1=P|2=Y|3=X|4=U|5=V|optSpec=8>" <CutLine=Esrp><<CutT="F"Dim="0.000"Rip="0"ID=""EtiID=""/> <! Cote et répetition !> <CutLine=t>Dim=""Rip="1"ID=""EtiID=""/> <CutLine=c>Dim=""Rip=""ID=""EtiID=" <CutLine=Cp>(<i|perCutMap|optSpec=12>) <CutLine=c>"/> <! Description des rainures (non utilisé) !> < <! Liste des pičces !> <varUnit=md2z> <! millimčtres avec 2 décimales !> < <tab=2><<EtichettaId=""Codice="<custom=1>"Lunghezza=""Larghezza=""Richiesti="<q|total>"CodiceBordo1=""CodiceBordo2=""CodiceBordo3=""CodiceBordo4=""Job=""Campo1=""Campo2="<custom=1>"Campo3="<custom=2>"Campo4="<custom=3>"Campo5="<custom=4>"Campo6="<custom=5>"Campo7="<custom=6>"Campo8="<custom=7>"Campo9="<custom=8>"Campo10="<custom=9>"Campo11="<custom=10>"Campo12="<custom=11>"Campo13="<custom=12>"Campo14="<custom=13>"Campo15="<custom=14>"Campo16="<custom=15>"/> < < <! Fichier liste des plans de coupe !> <resetFile=..\xMix\*_???.XMix|start=1> <varSep=>< <<HeaderDescrizione="<title|fmt=50>"Import=""Date="12/01/17"/> < <Header=nbr> < < <newFile|%=99> <tab=2><<RigaMixFile=".<fileName|main|path:rel=..\.>"Rep=""Pacco="1"CambioMateriale="0"/>< <
This is very useful information thank-you very much for posting.
I’m sorry not to have replied sooner.
If you would like to post more and interact with our Premium Support subsribers, we can set you up as a Premium subscriber for free.
We could also offer to pay for relevant and helpful posts.
If this interests you please use our contact form and write to Stefan.
Thanks again for your post and I hope that we will be talking again soon.
@ECHO OFF &SETLOCAL enableDelayedExpansion &SET "filename= <File Name> "&echo [PARTPROGRAMNAME]=!filename:~0,-4!_output.pgmx;[CODE]= <Cabinet> _ <Piece References> ;[MATERIAL]=all;[QUANTITY]= <quantity> ;[EXTRAQUANTITY]=0)>>CSV.csv
