vcarve pro|Forum|WOOD DESIGNER
OfflineHi Mohamed
Our software should work with your machine, however, I would strongly recommend that you download the trial version of VCarve Pro and machine at least one of the “Evaluation Files to Machine” that are included with the trial edition of the software, to test the output from the post-processor with your particular machine.
Trial Download: [Permission to view this media is denied]
Once installed, on the start screen select “View Sample Files”.
This will open your Web browser (such as MS Edge or Chrome) on the Machinable Tutorials Page.
Here are a number of tutorials you can output the toolpath for.
The “Bulls Head” evaluation file, is usually a good test of a machines 3D capability.
The “Avalon Sign” contains some arc moves in the profile toolpath and would ensure that the arc configuration of the post-processor matches that required by your machine.
The trial edition includes a Rich Auto A11 Post Processor that should work with your machine, so you can test its compatibility.
You can see the Machine Configuration Guide tutorial video here: [Permission to view this media is denied]
video=machine-configuration-guide
OfflineHi Mohamed
this is a holding message to inform you that we are investigating.
We will revert asap. It could be of help to send us your current gcode for a simple part.
Provide us with the part information and the Gcode. Please use a simple rectangular geometry with a few drillings and profiling.
