we can help me whit a dxf file en cutting list|Forum|WOOD DESIGNER
May 23, 2019 - 8:20 am
Hi Rene,
May I make a couple of suggestions, before I send you the manufacturing files?
You could add a landing step and eventually incorporate a riser on the last step to hide the joist.
The shape of the  stringers could be smoothed a bit and making the lower right string priority to the upper will eliminate the sharp point and make it easier to get a clean cut.
3d01.jpgImage Enlarger
Other wise the stair should work in the space you have.
We can send the DXF and or the MPR files but  DXF will be easier as the MPR needs to be set up with tool numbers and the woodwop variables according to the machine that you will be using.
The DXF files  can be loaded into WoodWop and tooled manually.
Can you tell me which stair file and what format you would like us to process?
May 21, 2019 - 11:23 am
I’m new on the stair design software, and make a stair design for a stair I want to build.
Can someone help me to get a DXF file or woodwop files (MPR, MPRX)  and a cutting list??
PHOTO-2019-04-19-12-08-16.jpgImage Enlarger
best regards,
Rene van hoof
Guest(s) 26
Topics: 3003
