Xxl-pgnx|Forum|WOOD DESIGNER
Xxl-pgnx
May 18, 2022 - 10:58 am
Extra information to be converted  make sur your tools number are well completed into PP setup, this point are controlled by Xconverter
For example milling tool E101 become 1001 for pp setup
All the best, Alexandre
May 13, 2022 - 11:59 am
To send files ONLY please use our contact form.
We will not answer technical questions by mail wink.
Online did you select the patch for the Xconverter.exe files?
As I don’t have it, I can’t send a suitable screenshot.
May 13, 2022 - 8:26 am
Alex said
Can you upload cabinet used and Post-Processor setting as *.Zip?
The files are not converted from xxl to pgmx or exported at all?
pp.pngImage Enlarger
1* Can you process an update by downloading installpolyboard.exe from this page (more information here) , then process news export
2* May update have reset option due to bug correction, Like attached Screenshot, please Set option “File Name format” “Without Accent ans special characters” , then process news export.
Hello Alex,
i have manage some to work but machine parameter is Null after x converter,  i have to re enter machine parameter in my maestro to work My machine Work with parameter  (DC)
can i have ur mail id i cant up lode post processor report.
May 10, 2022 - 7:26 pm
May 10, 2022 - 5:18 pm
Hello
when I convert xxl file to PGMX all parts are not converting only vertical and dividers parts which only with drilling programs are converting .
The problem is parts with groves and routing job are not converting.
it was fine in my PP.7.05 after converting 7.07 it creat problems.
can anyone Help me
Guest(s) 50
brendan kavanagh: 236
Emmanuel Sacco: 210
Zaheer Abbas: 201
Tom Jackson: 142
Rooms Made Simple: 132
MobLux
Valentin Zarzara
Kendal Anderson
Sarah J0hnson
Andreas Nygårds
Nicolas LEBRETON ROOST
Luka Savić
Lee Gent
A S Brighton
Tobias Briander
Topics: 3062
Members: 602
