Back Panel and Face Frames|Forum|WOOD DESIGNER
OfflineHi again,
Sorry I forgot to answer your question about the back grooves.
To make it easier for us to follow, can I suggest that you post a thread per subject ?
In your cabinet, you can adjust the depth of the back groove either using the panel Properties-Links menu :
You can also use a specific sub method, although it seems that you are not using a sub method to set up this cabinet.
OfflineHi Buddika Thusitha,
There are several ways to change the frame sections and this depends on how you are working and how you have set them up.
If the component is in bar material, the simplest way is to just change the material in the Properties list:
If the component is in a Quick Design design material it’s possible to change the Quick Design material specs:
It’s also possible to set the components up as panel materials, in which case you can change the width using the Assembly Edit button:
Hope this is helpful,
Dear Ness,
OfflineHi Thusitha, I think you probably saw Ness’s reply to one of your other queries. He was away yesterday and today, and we need him to take a look at these particular points, so we apologise for the delay. He’ll take a look at your queries on his return. Best regards, Stefan
Dear Ness / Stefan,
We raised this at the team viewer session, but it was not possible to finish at that time, and we kept it aside.
Here, when we add the middle panel, as per the second image, the front piece gets divided in to two. But we need it in one piece. Please show us how to do that.
Thusitha
OfflineHI Thusitha,
No problem to draw these designs in Polyboard Pro.
best regards,
Stefan said
Here are the other attachments I’ve resized for the forum.Thusitha, when you click on ‘upload attachment’ you will see the maximum size allowed. Please resize future images so they can be uploaded and seen on the forum.
Thanks, Stefan
Dear Ness,
Please check this attachments and confirm whether all these can be done with Polyboard Pro or not.
Thusitha.
