BASE CABINETS with VERTICAL STREACHERS |Forum|WOOD DESIGNER
OfflineHello Ramin,
You are very close. Please see the following video with an explanation:
OfflineThe solution i found only works if i do everything in this order :
– NIL shelf ( distance from the top = to my strechers )
– Add strechers -18mm ( the thickness of the future door / front )
– Add drawers after.
If there is another better way please let me know, if i dont hear from you i assume this is the way.
Thank you !
OfflineHello Isaac,
Thank you again for the quick answer, although this is the method i used to create it myself, i did learn some new things while watching ur video.
I have just created step by step what you did, and i get to the same issue. I cannot add drawers or doors after creating this, it allows me to click on adding them , it just wont do anything after i press OK.
I attach my saved project, maybe u can have a look ? ( i didnt assign yet fittings for the strechers )
Thank you !!
OfflineHello Ramin,
I have created a video showcasing how PolyBoard is designed to be used. I recommend not focusing on our example methods, but rather creating your own manufacturing methods that are specific for your manufacturing standards.
For more information on creating these in your libraries, please see the following information:
OfflineHello,
I was suprised there are no pre-made parts like this very basic and often needed SINK BASE CABINET.
So i’ve tried myself and made a few variants of vertical cabinets for sink, where the strechers are not horizontal, but like in the picture below:
I have used different methods but every time there is a problem with them, or the strechers will dissapear if i want to remove the drawers and add a door instead.
Or they wont let me add doors and drawers.
What is the right way to build them in order to be able to add and remove or edit doors and drawers afterwards ?
Thank you !
