Bookcase - Cabinet File - request|Forum|WOOD DESIGNER
OfflineHello Michael,
Sorry I missed that detail, see the file attached.
OfflineMichael,
See a new PDF attached. This one has a grouped cutting list.
OfflineHi Isaac,
Thank you for sending the cut list using imperial measurements, much appreciated!
You don’t have to modify the cut list, but I haven an inquiry. Is there’s an option to export the .pdf file, numbering the quantity of duplicate cuts? For instance; top/bottom, left/right frame, uprights, shelves, and drawers have many duplicated cuts. In the final product sheet, it lists each of these separately with a quantity of 1. Whereas the cut list can be shortened significantly using higher quantities.
Cheers,
Michael
See your files attached. Note, I have exported in imperial units, and with overall dimensions. Let me know if there are any problems.
OfflineHey!
I’m new to Polyboard. As a DIYer that likes to build furniture and renovate my house I found Polyboard to be a quick and design friendly way to iterate on designs. The project I’m looking to receive a cutlist for is a built-in bookcase. I left room at the top for an additional 3/4″ board.
Thank you for your time,
Michael
