Building a cabinet of aluminum bars|Forum|WOOD DESIGNER
OfflineHello Hassan,
Yes, that will work as well. You may find it is a little more tricky having them separated, although it will give you greater flexibility with how you can work on each of them.
Let me know if you have any further questions.
OfflineHello Isaac,
Sorry for the delayed reply,
Thank you for the continuous support from you.
I think separating the unit to two units will be better to get better results the case is a separated unit from the facade which will be a unit without a carcase.
then i align the two units in a new project after setting up a method for the caculations.
please let me know what you think.
Regards, Hassan
See the video below:
OfflineHello,
I wonder if i can build a cabinet of Aluminium bars like the unit attached to this message
I tried to get the correct shape to what I am looking for but the issue is that to create the frontage frame i lose the ability to add drawers or doors
I hope I have clarified my question in a good way.
Looking forward for your support.
Hassan Sultan
