corner cabinet design|Forum|WOOD DESIGNER
Forum Posts: 954
October 6, 2017 - 9:03 am
Hi Jack, sorry when I changed over to imperial I didn’t have the correct fractional setting (it was down to 1/2″ instead of 1/16″). It should be ok now, attached. Thanks
  • sp_PlupMedia jack-travis-01-v01-revised-061017.zip(324 KB)
October 5, 2017 - 4:57 pm
Stefan said
Hi Jack, here are you files, I’ve done them in imperial rather than metric, hope that’s right. If not, just let me know. Please note this is a file processing service, we haven’t checked over your design. Hope the build goes well. Cheers, Stefan
Stefan,
curious, why did the process you ran come out with all thickness of 1″ versus 3/4″ and all the grooves came out 1/2″ depths and 1″
widths?  all my wood thicknesses on the file are 3/4″ and the depths vary from 1/4″ to 3/8″.
jack
Forum Posts: 954
September 25, 2017 - 10:13 am
  • sp_PlupMedia jack-travis-01-v01.zip(319 KB)
September 24, 2017 - 4:25 pm
FILE ATTACHED:
September 24, 2017 - 4:15 pm
Ness,
looks like I will need you to print me a cut list with drawings and cut dimensions. I can’t get enough detail with my lite version. what is my price as a premium member?
file attached.
jack
September 15, 2017 - 9:39 pm
Stefan,
THANKS! GREAT!
Forum Posts: 954
September 15, 2017 - 9:21 am
Hi Jack, Ness is away this week. In the meantime can you let us know if this solution works for you. Explode the cabinet to easily delete all plinth elements, select the plinth volume/empty space below the cabinet, and add a new plinth just once with the shortcut button, then apply a plinth front back and sides:
Polyboard-plinth-front-back-sides.JPGImage Enlarger
If that’s not what you’re after, let us know and we’ll get back to you as soon as possible. Best, Stefan
September 14, 2017 - 10:28 pm
Ness:
Please review the attached file to address my questions:
1. how do I add the sides to my plinths
thanks for your help.
jack
September 12, 2017 - 7:22 pm
Ness,
also, program is only letting one leg of the plinth (frontage)?
September 12, 2017 - 6:26 pm
Ness,
cabinet design attached.
regards,
jack
Guest(s) 80
Pavel Kudrjavtsev
Javier Velázquez
Topics: 2933
Members: 554
