Cutting list to Excell|Forum|WOOD DESIGNER
October 4, 2017 - 6:41 am
Hi Thusitha,
The problem is that when importing you text file Excel interprets the thickness expressed as a fraction like “3/4” as a date, so inserts  03-april.
Depending on the Excel version you are using, one way to avoid this, when importing, you can set the column type to “text” :
import-010.pngImage Enlarger
Note that if you need to calculate the column you’ll have to change the formatting back to fractions.
I’m not an Excel expert so there might be a better way to do this, so you might want to search the internet for another solution that keeps the value  as a fraction.
hope this is helpful,
October 4, 2017 - 3:47 am
Dear Ness,
Please find the attached files, let us know the solution.
Thank you.
Thusitha.
October 3, 2017 - 12:24 pm
HI Thusitha,
Please post the Polyboard file and the exported text file so we can compare.
best regards,
October 3, 2017 - 12:15 pm
Dear Stefan,
We only found from you, the same attachment we had uploaded for your perusal. Kindly check the mail and send us the solution, and a video as well, that would be much helpful.
Thusitha
Forum Posts: 928
October 3, 2017 - 11:37 am
Here’s the file uploaded. These files are now allowed on the forum. If you have a problem with the file types, one solution is to upload them inside a zip file. Best regards, Stefan
October 3, 2017 - 7:18 am
cutting-list-excel.JPGImage Enlarger
Dear Ness,
How are you?
We checked and followed the video you sent us on transferring cutting lists to Excell sheet. Thank you for that.
The attached shows that we don’t get the thickness correct. Please advice us the way to get it. If you could send a video for that as well, we would much appreciate that.
We will mail you excell document which is not possible to attach here.
Thank you.
Thusitha.
Most Users Ever Online: 365
Guest(s) 17
Tom Cleaver: 164
brendan kavanagh: 156
Conor Devoy: 146
Zaheer Abbas: 122
Blake Simpson: 104
Robert Coxhead: 74
Patrick Maylor: 74
Andrej Potočnik
Olga Safari
Greg Allen
Maximo Vinet
ben levene
roni ben ami
Kateryna Druzenko
Joseph El Hajj Moussa
razvan george tomas
Dennis Nwachukwu
Topics: 2345
Members: 350
