Door handles left and Right in material style.|Forum|WOOD DESIGNER
ok, for the handles I have no solution but for “Slack” it’s good to have 1 or 2mm between the facades, and to cover the vertical division
hi Alex No problem.. depending on the type of product we make,, somtimes it is 7mm and other times 4.5… the main thing i need to know if it is possible to have a leteral slack on the left different than the right see pick.
dont forget the q about the handles on double doors and handles.
Sorry, for the delay and my English,
Your request took me a bit of analysis to see and understand how you build your cabinet.
Is 7mm of grooves good for the doors and drawers to cover Vertical division? and have 2 mm between the facades ?
Hi Paul,
Can you upload your cabinet with this method?
Then can you let me know which version you are using now?
But I think you can’t find a better way because the structures are applied to the panel and not to the fittings link like hinges where you can use Open or Fitting Side.
Cheers Alexandre
Hi When I make a style structure for a door so its added automatic.. can one make a left and right door because it always put the handle.. either ons just the left or right depending on my stucture,, even in a double door the handle of 1 door wil always be wrong side..is there a fix??
Kind regards
Paul
thanks
