Thanks for answers.
Tell me please, how can I change the names of cabinet sides.
For example at the moment I have cabinet name - Model.
And when I`m making cuttinglist - there are righ side and left side.
In which settings I can change name of right and left side - so it is in Latvian - labais un kreisais?
Thank you.
Hi girts,
Do not use overpassing as a double back is an inside element and will cut the lower panel in all situations.
I rectified the inner tooling to match the dimension excluding the double backs. After that, you have to change the type on the double backs in link to the bottom to groove and set groove on 16mm to overpass the bottom panel
Girts Martinsons1 Guest(s)
