Drawer front - structure|Forum|WOOD DESIGNER
January 24, 2025 - 8:07 am
See attached:
Girts Martinsons
Forum Posts: 31
January 23, 2025 - 12:57 pm
Isaac said
Hello Girts,
Currently you are unable to edge components in an assembly. This is currently a limitation of the program.
You can add edges to the sides of the total drawer front itself, the only recommendation I could make would be to double the thickness of each edge application.
I’m sorry that I can’t help further on this issue.
Thanks for answer – could you please describe what you meant with – to double the thickness of each edge?
thanks
January 23, 2025 - 8:29 am
Hello Girts,
Girts Martinsons
Forum Posts: 31
January 22, 2025 - 2:15 pm
Could you please suggest – how it`s possible to make this structure, that in cutting list it is edgbanded from all sides?
I have created as a cross bars – but when it`s made with surface split – it`s not possible to make grooved glass.
Please see – drawer nr 3 – in this project:
3-drawer.jpgImage Enlarger
Guest(s) 46
