Face frame cabinet middle rail|Forum|WOOD DESIGNER
Forum Posts: 2128
March 25, 2021 - 9:53 am
In the video we show you a method using 2 Nil shelves, instead you can use a classic shelf on top then change the double-back to overpassing.
Or use nil to delimit, that lets you add drawers or doors afterwards
nil.pngImage Enlarger
add.pngImage Enlarger
March 25, 2021 - 9:18 am
Hi Ness
Thank you for you video very helpful
What about if you want to keep an actual shelf being the rail, example to be used on a base oven housing cabinet with a drawer underneath?
Please see file attached
Thank you in advance
March 25, 2021 - 7:45 am
Hi Helder,
Just to explicite Alex’s video, here’s another quick video that I’ve made for you:
Best
March 24, 2021 - 7:47 pm
Hi Alex
Thank very much for your help
Kind regards
Helder
Forum Posts: 2128
March 24, 2021 - 3:18 pm
OK, for middle rail use 2 nil shelves to separate
and for oversize control Sub-methods Groove and oversizing you’re using
All the best, Alexandre
March 24, 2021 - 12:38 pm
Also I’m having a problem with the cut list
When i highlight the part examples a left side is showing 760mm x 570mm which is the righ size for our base cabinets but when i try to print, on the cutting list is showing as 765mm x 570mm which
March 24, 2021 - 12:33 pm
Hi Alex
Here is the file
Many thanks
Forum Posts: 2128
March 24, 2021 - 10:42 am
Can you upload your cabinet?
That’s clearest to let me see what you have done
Thanks, Alexandre
March 24, 2021 - 10:20 am
Hi, I’m trying to build a kitchen base cabinet with 2 pan drawers, face frame stile cabinet with middle rail between drawers, for some reason pan drawer at the bottom once you add it it pushes back the middle rail, i have tried to add a nill shelf just bellow the middle rail to separate the zones but for some reason it still doing it
Any suggestions?
Thank you in adavance
Kind regards
Helder
Guest(s) 40
brendan kavanagh: 227
Emmanuel Sacco: 196
polyjohn
Maxime Marengere
everslyjoinery
Topics: 2903
Members: 539
