First project Cutting list|Forum|WOOD DESIGNER
October 4, 2024 - 8:48 am
1°)
Bars assembly only provided bar cutting list,
Assembly-Bar.pngImage Enlarger
To get full details you must define them as panel, thickness are provided by panel’s material, and need to define Width,
Assembly-Pan.pngImage Enlarger
Please find sample with your “Left frame” as panel
>Caution by looking plan I see you have made a mistake , your hinges on Fixed upright must by set with S-App (semi-applied hinges)
On properties menu click on the “…” , then from fitting link menu change to S-App hinges
hinges-fixed-upright.pngImage Enlarger
I checked your counter and the PDFs and didn’t find any problems, but I did find some strange point positions, which caused rounding to appear in the PDFs.
(Left Countertop)
Points.pngImage Enlarger
The circle is here converted into a segment, and the dimensions are cumulative dimensions.
ptp.pngImage Enlarger
but the size at the bottom reflects the offesting in the drawing
Gregorio Bruno
Forum Posts: 5
October 3, 2024 - 4:26 pm
sorry about that and thanks for updating the plans.
I had a look at the cutting list and I would like to ask you some clarifications, as not all the elements are in the plans and pdfs and some measurements do not seems correct.
I’ve attached the pdf generated with your last submission and I’ve noticed:
1) In the cutting list at the top I can see Wood 50×22 element 17 and 18 for both frames but they are not in the plans or the Pdfs. These pieces have recesses and other elements so I was expecting to see them in detail.
2) the counter top elements dimension do not seems correct in the pdf. The cad seems correct.
Can you advise
Greg
Forum Posts: 1583
October 3, 2024 - 11:47 am
Greg,
The terms don’t allow for rectification, although I have attached the updated files for you.
Just be cautious in the future :).
  • sp_PlupMedia Gregorio-Bruno-Version-2.zip(2 MB)
Gregorio Bruno
Forum Posts: 5
October 3, 2024 - 11:14 am
thanks for sending the files. The intended modification was only one opening on a side panel.
I don’t know what happen but the file that you received didn’t have this modification and it is exactly as the previous one.
I don’t want to abuse of your patient so I understand you cannot keep sending cut list files.
For what is worth attached the correct file.
Greg
Forum Posts: 1583
October 3, 2024 - 11:02 am
Greg,
Find you files attached.
  • sp_PlupMedia Greg-Bruno-1.zip(2 MB)
Gregorio Bruno
Forum Posts: 5
October 3, 2024 - 10:37 am
Please try this. Is the same as before, there is only a minor change on the left cabinet.
thanks
Forum Posts: 1583
October 3, 2024 - 10:35 am
Greg,
I am not able to download this file.
Would you please try uploading it again?
Gregorio Bruno
Forum Posts: 5
October 3, 2024 - 10:25 am
Hi there,
Last minute modification…please ignore previous project.
Can I have cutting list for the attached updated project?
Greg
Gregorio Bruno
Forum Posts: 5
October 3, 2024 - 9:53 am
I’ve been using your demo software to design my first project. Software is great and have a very user friendly interface 10/10.
Can I have the cutting list and dxf drawings for the attached project please?
*** Image attachment removed from post content ***
Greg
Guest(s) 37
Conor Devoy: 173
Jan Peter Oelen
ANDI MÖÖBEL - Tarmo
Topics: 2964
Members: 562
