Front cross bar overpassing the side and uprights|Forum|WOOD DESIGNER
August 8, 2018 - 6:03 pm
Hi Dam,
Place middle upright panel before the cross bar and make the assembly to the right side a groove with a depth equal to the side panel thickness and the assembly to vertical upright a groove with depth equal to thickness of vertical division + interior volume + thickness of left side:
front-cross-bar.pngImage Enlarger
Make cut out of left side with inner tooling:
front-cross-bar-010.pngImage Enlarger
Hope this is helpful.
August 8, 2018 - 4:06 pm
I want to make the front cross bar of the cabinet go through the side and upright panels.
I tried to make a inner tooling to cut the corner of the side and upright panels but when i insert the upright and make it groove type but the software did not understand the space cut by inner tooling in the corner of the side and upright panels, so that the side and upright panels split the front cross bar into 2 separate parts.
Can you help solve this issue?
Thank you.Cutting-corner.JPGImage Enlarger
Most Users Ever Online: 286
Guest(s) 15
Conor Devoy: 139
Zaheer Abbas: 96
Patrick Maylor: 63
Vicky Hope
Stephen Vis
James
douaihytech
Emmanuel Sacco
MateiCL
Brian Serrao
Allister Griffin
Martin Ahlström
luis parreira
Topics: 2158
Members: 287
