Hettich Actro YOU Avantech drawers and rules|Page 2|Forum|WOOD DESIGNER
extra information by mail
Alex said
For drawers, you have 4 levels of methods and sub-methods
-Firstly, the generic methods for starting the planning of complete drawers for a height.
>Sub methods Materials for set component thickness when you add drawers
>Fittings sub-methods for defining the fittings to be used when adding drawers
>Drawer sub-method for defining the size of components
I have upload cabinet AvanTech YOU 101 for exemple
Hope that’s helpful
my PB is not opening your file – says it`s “unexpected file format”
Hope that’s helpful
Tell me please,
How can I create internal drawers panel?
For example for Hettich Avantech You.
It has to be cutt in specific length – how can I create the structure?
And every time I`m making the built in drawer – it is already giving me in export material – correct dimension?
Thanks.
Sorry my English is limited and I’m not sure I understand your question
You show me sub-methods fitting for add drawers runner and after drawers length working with drawers sub-methods
Did you already visit our help center for more explain? Drawers
Instead I will ask Michel if he can help you this Monday
when you install the latest update, it also updates the preferences, to match the new libraries
All the best, Alexandre
Hello Again 😀
I uploaded latest libaries.
And created new drawer manufacturing methods for Atira.
In Sub Methods I choosed specific lengths which are necessary.
But when I`m pushing – add drawers – there appears all lengths (from 260 to 650) Why so?
Have I done something incorrectly?
THanks.
Actually standard drawers are add with classic rules Singles, reverse (from bottom), Zone inside
To do this you can add divide zone with Nil Shelf, and add first built-in drawer with nil frontage,
Then add a secondary drawer applied in Global to cover the first drawer.
Create a new fixed distance rule, with same distance as nil panel to bottom.
It stays you to removed Built-in drawer fitting if add with fitting sub-methods.
Best wish, Alexandre
