Hinged Shoe Cabinet|Forum|WOOD DESIGNER
Hinged Shoe Cabinet
Tom Jackson
Forum Posts: 142
February 11, 2025 - 2:00 pm
Brilliant thanks for this – At a quick glance this looks like it might work, but ill have to sit with Chris to discuss this further when he’s back off site.
Thanks again for the support – chat soon.
Cheers,
Tom
Forum Posts: 1781
February 10, 2025 - 3:02 pm
Tom,
See the attached cabinet. You can restore the fittings and see what I have done.
Please confirm all drillings suit your needs. I believe that they are correct, but the technical data isn’t very clear in all areas. Just confirm you are happy with the fitting.
Tom Jackson
Forum Posts: 142
February 10, 2025 - 11:10 am
Thanks for this, I really appreciate your style of painting a picture vs being direct and being clear.
Yes, I suppose we need to be specific to extract the most value. With that said, I just found a Hafele product that is better than the link I sent you, that also has the technical drawings: Hinged Shoe Rack – Hafele
A shame we can’t hinge the drawer in the software, but if we can build it with the correct drill holes etc, I don’t suppose it matters. I’ve measured a space in my house a product like this could fit, so lets use these dimensions: Total dims of 370mm (deep) x 910mm (wide) x 1,750 (high). These dims include a 40mm filler on the left and an end panel on the right. Using 18mm thick Finsa MDF boards.
Cheers,
Tom
Forum Posts: 1781
February 10, 2025 - 10:44 am
Hi Tom,
See attached.
Tom Jackson
Forum Posts: 142
February 10, 2025 - 10:06 am
Hello Isaac,
I’m trying to build hinged shoe cabinet system for a client that rotates 45 degrees towards you, and you just drop the toe into the slot.
Please follow this link (I hope it works):
Hinged shoe storage system
Manual Link: [Subscribe to Premium Support to view this media]
tag=googshopuk-21&linkCode=df0&hvadid=697873309343&hvpos=&hvnetw=g&hvrand=9861666902820291972&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9191447&hvtargid=pla-2308768756790&psc=1&gad_source=1
It appears to be x2 plates either side, with a few planks across to connect them. This would allow the user to drop the shoes toe, straight down.
Please do let me know your thoughts on how this could be constructed.
Cheers,
Tom
Guest(s) 52
brendan kavanagh: 236
Emmanuel Sacco: 210
Zaheer Abbas: 201
Tom Jackson: 142
Rooms Made Simple: 132
MobLux
Valentin Zarzara
Kendal Anderson
Sarah J0hnson
Andreas Nygårds
Nicolas LEBRETON ROOST
Luka Savić
Lee Gent
A S Brighton
Tobias Briander
Topics: 3062
Members: 602
