HOLES FROM BACK TO TOP AND BOTTOM|Forum|WOOD DESIGNER
Forum Posts: 616
Just note with the video below,
The 3mm holes are drilled on a separate face to your Q-fix fittings.
Forum Posts: 616
Hello Emanuel,
I hope you are well.
Please send me a cabinet file and I will look at this for you.
With the CNC problem, please reply to my previous forum posts and emails. I need you to answer those posts so that I can investigate the problem you are having.
Emmanuel Sacco
Forum Posts: 60
July 5, 2024
July 5, 2024
hi isacc ,
i done a project of bedroom ,and need to put some 3mm holes from the back to the top and bottom,the back is overlaping both of them.when i am trying to do it ,on the bed side tabel it is not showing and on the chest is on the middel of hieght .
why is happening this pls .
ABOUT THE CNC PROBLEM DO YOU HAVE ANY UPDATE PLS .
THANK YOU
MANUEL
Most Users Ever Online: 365
Guest(s) 33
brendan kavanagh: 168
Tom Cleaver: 164
mark nichols: 162
Conor Devoy: 158
Zaheer Abbas: 132
Blake Simpson: 104
Tom Jackson: 83
Patrick Maylor: 81
roni vilavila
Miryahya Khameneh
mathew moule
Christian Lopardo
Romerworld
Evaldas Gudenas
Petr Břichnáč
Ar Te
Ilie Mihail
GERARDO MARMOLEJO
Topics: 2483
Members: 380
© Simple:Press —
