Overlapping fitting|Forum|WOOD DESIGNER
Forum Posts: 1444
OfflineHi Normunds,
If you would like your shelf to be fixed to your cabinet I recommend choosing a fitting that would allow this, or to offset the shelves from each other.
For example, this could be a shelf pin that is less then half the depth of the board thickness, or a CAM fitting with a short screw.
See the below example, the Cabineo 8 has a screw length of 7mm.
https://lamello.com/products/d…../cabineo-8
Guest(s) 41
everslyjoinery
Members: 537
© Simple:Press —
