Panel for plinth|Forum|WOOD DESIGNER
Panel for plinth
May 10, 2018 - 12:15 pm
Hi Hung,
Select sliding door when clicking add doors
sliding.jpgImage Enlarger
I add this link showing you several videos for the project mode
May 10, 2018 - 11:52 am
Dear sir,
 How made project like this (i have not yet make front panel of plinth like you)
and how can i add slide door of cabinet (hafl part above)? (please see attach poly file)
Tks
May 10, 2018 - 11:12 am
Hi Hung
here is a model made in project mode
May 10, 2018 - 10:14 am
Hi Hung,
This is possible (see attached cabinet file) that you can use to work on
In that model I added a free division 100mm from the bottom and made the bottom panel a nil material.
Add a double door at the top part and add shelves
Add a single door at the bottom part. This gives you the look you need. In the 3D visual the bottom door will open when you click on the open doors button but in the build you can just make it a fixed panel.
If you really want this to be fixed and not open in 3D then you could make it as a project. There the cabinet and the bottom panel will be 2 different create shape put together.
May 10, 2018 - 8:31 am
Dear sir,
 I can do:  change glass door but i have problem: after add upright and shelve i can not add door (out side) (please see picture). Or i have add door first and then add upright and shelve ?
About plinth – I can turn on red light part plinth as you show. But it’s still not what i want – i send you picture part plinth of cabinet i made (there a  panel over 02 side left and right). The structure like picture i drawHop-chan-panel-640x480.jpgImage Enlarger
Hop-chan-640x480.jpgImage Enlarger
Tu-ao-4-canh-640x480.jpgImage Enlarger
May 9, 2018 - 6:21 pm
Hi Hung,
you made a wrong build up of the cabinet. You used a fixed shelve as bottom part and made the actual bottom panel a nil panel. This is the reason why you are not able to add a plinth as these are to be situated below a bottom panel. So please correct this. You can achieve the same model of cabinet using the normal bottom panel but setting the side panels as overpassing the bottom panel and adding a needed length to it as I have showed in my earlier pictures
For the glass panel in the door you have to choose the doors 1 by 1and edit the structure by clicking on the 3dots button next to de the door name. Change the central panel material to glass called zz-glass,8.0
May 9, 2018 - 5:48 pm
Hi sir,
I have a problem: i want to 2 open door: with GLASS (in center) not wood as picture
Tks
May 9, 2018 - 4:58 pm
Hi Hung,
please attach your polyboard file
May 9, 2018 - 3:16 pm
Red-resize.jpgImage Enlarger
May 9, 2018 - 2:52 pm
Hello sir,
I have problem: i can not make it light up RED so i can see ADD PLINTH as picture
By the way, please show me add shelve after add door (i can not make – i have to delete door and add shelve then add door – it’s right? or have any another way?
Tks
Guest(s) 31
