pantry cabinet|Page 2|Forum|WOOD DESIGNER
Hi Jack ,
See attached . I managed to make the assembly without any problem with polyboard 6
I WAS ABLE TO MAKE A WOOD FRAME DOOR IN POLYBOARD 5 WITH A TEST CABINET. When I open in poly 6 light I can still work with the test cabinet but still cannot perform the function on my project cabinet. current pantry design file already has doors that cover 2 shelf openings but cannot change the door to framed using bars…….still no assembly/structure menu. tried to remove the door and shelf and still no assembly menu??
Jack
Ness or Stefan:
I have re-watched most of the videos in an attempt to add framed doors. However, when going to cabinet edit/properties/door/ I do not get any option for structure or assembly detail. I finally reloaded Polyboard after trying to reload polyboard-en. Polyboard keeps telling me “can’t find”/”may not have permission”/…….current quick design polyboard-en structure gives me NO STRUCTURE OPTION. However, I can add a door panel from the texture menus.
I hate to be a pest, but I am baffled.
Jack
Ness:
Thanks for the input. I can always glue the sides to get my desired widths. I would like to know how to add the constructed framed doors. I do not see any options in the door selection menu. I reviewed the video on framed doors but they appear to be routed/sculptured versus true frame and board doors? The 1-2-1 option cost is not a good option for. please direct me to the appropriate tutorial for designing a frame and board door.
thanks, jack
Hi Jack,
You’ll probably need to use the face frame methods and have some guidance.
We can do a mini-Team Viewer session to show you quickly how to start your set up, but you might find it more useful to have some a real training session with video recording of the session.
Training sessions are available from the 1-2-1 Training page here:
https://wooddesigner.org/train…..g-service/
Tell me when you would like to meet up and we can set up a Team Viewer meeting.
Hi Ness:
Finally resolved upload problem with Stefan’s help.
I have posted the finished cabinet we designed and a picture of the pantry cabinet I want to design and build.
I reviewed the tutorials you recommended and am still at a loss. I am trying to build the carcass sides with 2″ corner posts that I can groove and insert 3/4″ panels into. Since it will contain heavy items, I need the strength.
As always, I look forward to you guidance.
Jack
Hi Jack, can you check this video for uploading pictures: https://vimeopro.com/wooddesig…..rum-basics
Are you using the ‘upload attachments’ button then ‘add file’ and ‘start upload’?
Still having problems, please send me the image using the contact form and I’ll have a go. Thanks, Stefan
