printing a bar code label|Forum|WOOD DESIGNER
OfflineHi Thusitha,
For exporting cutting list to Excel, please look at the vidéos on this page:
For exporting bar codes just go to File>Labels Setup
click the panels or bars set up, and then the field you want to print in bar code.
Click “Options” and tick “Print as Barcode”:
Dear Ness,
Even though you are away, this is posted because you may check it on your return.
Please inform whether we can import the cutting list to EXCEL SHEET and proceed. If can, Show us the way to do that with POLYBOARD ?
Other option is how barcode printing is compatible with Polyboard? Please show us the way to do it.
Thusitha
Ness said
Hi Thusitha,There will be no problem to print your labels from Polyboard on this printer.
Polyboard uses the windows printer drivers so any printer run through windows will work.
best regards,
best regards,
Dear Ness,
In that case, Please inform whether we can import the cutting list to EXCEL SHEET and proceed. If can, Show us the way to do that with POLYBOARD ?
OfflineHi Thusitha,
best regards,
Dear Ness / Stefan,
URGENT MATTER
Dear All,
We are planning to label all the components of furniture items. There, we are going to buy a barcode printer. Attached are the details of the same. We need to know whether it is compatible with Polyboard.
Kindly inform us urgently.
Thusitha.
